Electrical Question (need help)
Old Mar 5, 2009 | 08:42 AM
harley-jones's Avatar
harley-jones
Default Electrical Question (need help)
I recently wired up a set of fog lights on my 08SG. I wired them exactly as the MoCo instructions were written.
That means that they are hooked to the low beam side of the headlight and will only light when the low beam is on, and they go out when you go to the high beam.
My question is..would there be any problem with changing the wire that runs to the low beam to the high beam wire behind the headlight?
My plan is to buy a headlight modulator to modulate on the high beam and also have the fog lights on. Then the fog lights would go out when you go back to the low beam.
I did find a company that sells a modulator that will modulate the low beam, but most recommend that you modulate the high beam.
Thank for your advise.
Old Mar 5, 2009 | 09:41 AM
harley-jones
I guess no electrical people are up yet!(lol)
I think I got wordy with my question. Simplified...
Has anyone hooked up their fog lights to work with the high beam instead of the low beams?
Old Mar 5, 2009 | 10:01 AM
iclick's Avatar
iclick
On my '07 SG the high- and low-beam wire gauges are the same, or at least the OD is the same, so there should be no problem putting the auxillary lights on that circuit. If you are running 55/60w headlight bulbs there will be 5w more current drawn in that configuration, but that won't be a problem especially with a modulator. The modulator will actually allow the bulb to run cooler. I've been running 80/100w headlight bulbs for years with no problems with wires, switches, or connectors--so your proposed configuration should pose no problems.
If I were going to run higher-powered bulbs I would probably put the auxillary lights on a relay, which is an easy install for only a few dollars. It will also provide higher output for the auxillaries if the main power source is the battery, as from that location it should run ~13.5V whereas at the headlight it will be lower at around 12V. Motorcycle Consumer News tested a headlight relay in their latest issue and connecting to the battery using a relay provided 50% more light output than in the stock location. The downside is that a typical halogen bulb will lose a full 75% of its longevity running at that higher voltage.
I haven't seen a modulator that works on low-beam and I don't know why you'd configure one that way. The low-beam in daylight is almost invisible and you need the high-beams just to be seen at all. I've been using the Kisan Pathblazer now for about seven years and I recommend it.
Old Mar 5, 2009 | 10:09 AM
hojones's Avatar
hojones
I agree with Iclick on this. If you have any douts put the relay in anyway. It's a simple install and the only load you will add to the high beam circuit is what it takes to trigger the relay and that's insignifigant. All you need is a relay from any auto parts store.
Old Mar 5, 2009 | 01:28 PM
harley-jones
Thanks you for the info! www.kriss.com has a low beam modulator, but I agree it would be worthless IMO.
Old Mar 5, 2009 | 03:45 PM
gmurdock's Avatar
gmurdock
In some states you are suppose to only run you fog lights with low beams. I connected mine to the ACC switch on the dash so I could chose when I wanted the extra lights. If I have a group following me it is always nice to have them shut off their spot or fog lights so I can keep track of the group. Now some do some don't it depends on if they have lead many people & are the curiosity ones. I just spliced the wire under the dash. I also could not find the ACC plug under my seat. The only plug I could find was hot all the time. If anyone has a Pic of both plugs under the seat please send it to me I can change it.
Old Mar 5, 2009 | 04:05 PM
fairplay's Avatar
fairplay
follow the directions as moco states, just hook up the high beams instead of the low beams. The fog lights do not know where they are hooked to.
Old Mar 5, 2009 | 04:15 PM
harley-jones
I just came up from the shop and that is what I did and it works fine.
I just ordered a headlight modulator from Kisan Technologies part # P115W-S it was $117.30 delivered.
Between the Fog Lights and the Modulator I hope I am a little more visible.
Thanks guys!
Old Mar 5, 2009 | 04:41 PM
FastHoss's Avatar
FastHoss
I hooked mine under the fairing to a power wire from maybe a siren or some kind of cop light that the standards have under there
Old Mar 5, 2009 | 05:10 PM
sgdiesel's Avatar
sgdiesel
In principle there will be no difference between wiring to the low beam or the high beam. My only concern with some of the suggestions made here and with your plan is whether your intend modulating the fog lights as well?
Assuming your are NOT modulating the fog lights, you need to ensure you are tapping in on the supply side of the modulator for the fog light, rather than on the output side. If you plan to use a relay, then that also MUST be on the supply side to the modulator. Trying to modulate a relay could give you some VERY interesting results.
Reno007
Electrical/Lighting/Alarm
Apr 19, 2017 10:47 AM
rcc
Aug 7, 2008 11:31 AM
ozzy07840
Mar 13, 2008 05:57 PM
Wide06
Feb 29, 2008 11:21 PM
TexasBowhunter
Apr 23, 2007 09:46 PM
