headlight Mod
Old Apr 22, 2007 | 10:01 PM
TexasBowhunter's Avatar
TexasBowhunter
Default headlight Mod
There was a mod a while backwhere the high beam comes on when the light switch is inthe low and both the high and low is on when the light switch in on high?
If so where is this wiring diragram of the mod at?
I seem to have misplaced my link...
Thanks
Paul
Old Apr 22, 2007 | 10:19 PM
HiTech's Avatar
HiTech
Default RE: headlight Mod
I would be careful of that Mod. You wiring will be drawing the wattage for two headlight beams. Your socket will most likley over heat, and cause you troubles. I know there is a mod to keep your spot lights on while your high beam is on.
Old Apr 22, 2007 | 10:36 PM
TexasBowhunter
Hi tech,
You know where this mod can be found?
I presently have the mod for the passing lamps and hi beam...
Thanks
paul
Old Apr 23, 2007 | 02:49 AM
TexasRedneck's Avatar
TexasRedneck
You can do it - it's in the electrical section IIRC. To me, it ain't worth the hassle. There's no issue that I can see with the wiring circuit, since HD sells a dual-beam headlight kit that runs both lamps with the high beam "on".
Old Apr 23, 2007 | 05:32 PM
nmfxstc's Avatar
nmfxstc
Did mine 18K miles ago...there i no draw issue and it is a simple wire splice...no reason not to do it!
Old Apr 23, 2007 | 06:03 PM
tireater's Avatar
tireater
I would try the Silverstar H4-ST bulb first BEFORE I messed with wiring - GREAT $20 UPGRADE...!
Old Apr 23, 2007 | 09:46 PM
TexasBowhunter
Texas Redneck,
electrical section IIRC????
Wheres that section at?
I think I found what I remember seeing in Todds harley Pix's...
Nmfxstc.
That was my understanding as well
That info came from someone that has more knowledge about the electrical/electricity then I...
Thanks
paul
Reno007
Electrical/Lighting/Alarm
Apr 19, 2017 10:47 AM
Elqueso2
Apr 10, 2013 12:40 PM
Maidenas
Apr 5, 2011 04:17 AM
Nautilus
Apr 4, 2010 04:02 PM
CSI
Sep 14, 2006 11:32 PM
