Heritage Headlight Issue
Old Oct 12, 2013 | 05:08 PM
zyepod's Avatar
zyepod
Default Heritage Headlight Issue
Hoping someone can give me a little help here. My warranty has run out so Harley won't give me the time of day unless I have my wallet out when I walk up to the counter...
I've got a 2011 Heritage and noticed the other night that my headlight seems to brighten up and then dims back to what I'd call normal. When it brightens up I also notice the light in my instruments (speedometer) goes out. I had a harness that keeps your spot lights on while your headlight is on bright and a harness that makes my blinkers work as brake lights... I removed both to see if they were the problem. Made no difference if they were installed or removed... My bike is also dragging on start-up to the point it makes my odometer reset back to total miles... I've removed my battery had it tested (it's good) cleaned the post and wires good makes no difference... I don't ride at night to often so I'm not sure how long this has been going on. Oh I still have not reinstalled my wiring harnesses... Appreciate any help...
Old Oct 12, 2013 | 06:24 PM
Gman in NC's Avatar
Gman in NC
Sound's like you have a problem with voltage regulation.
Old Oct 12, 2013 | 06:53 PM
TheTroupe's Avatar
TheTroupe
what he said.
And because your warranty is over and you might have to pay for service/diagnostics, don't **** and moan about it.
Old Oct 12, 2013 | 07:02 PM
fcsallan's Avatar
fcsallan
Start with the easy stuff first. Test your battery, Check the connections to the battery and ground, make sure there are no lose wires in the headlight bucket area.
What you are describing is either a regulator issue or more likely a ground issue. When one system has an effect on another like your gauges going out when this happens, it typically means the system is either getting voltage or ground through another circuit.
Also, not to sound like you don't know what you are doing here, but have you made any changes lately? Added anything moved your handlebars, added lights etc? Sometimes the simplest upgrades have an effect on other systems that we overlook.
Old Oct 12, 2013 | 07:58 PM
checkers's Avatar
checkers
Everything you listed goes directly to battery cable connections or battery. If you are positive your cables are clean and tight on all ends I would suspect battery or several other things.
Old Oct 12, 2013 | 08:52 PM
zyepod's Avatar
zyepod
Only thing I added was the Harley bought harnesses that made the rear blinkers act with the break light and the harness that made the front spot lights stay on when you switched to bright lights. I removed both to see if they were the culprit but nothing changed. I also looked behind the head light to see if there was a wire chaffing... Nothing... This electrical problem is over my head as I'm no electrician was just hoping for a possible easy test to rule out or claim the problem...
Old Oct 12, 2013 | 08:55 PM
zyepod's Avatar
zyepod
I had the charging system checked by Harley... They said all was ok...
Old Oct 12, 2013 | 09:01 PM
zyepod's Avatar
zyepod
I removed the battery and had it tested at Advanced Auto. They said the battery was fine... I removed the cables and used a wire brush to clean the battery post as well as the cables. Tighten everything very well.. I feel the connections are good. I've thought that maybe the battery has an internal problem that maybe the load test ant showing and have considered another battery. Was trying not to buy a $100 battery...
Old Oct 13, 2013 | 05:07 AM
oct1949's Avatar
oct1949
Check both ends of Ur ground cable, not just at the battery, it could be the prob also.!
Old Oct 13, 2013 | 06:07 AM
RANGER73's Avatar
RANGER73
When dose the speedo blank out, is it when the head light gets brighter or when it gets dim?
If it's when it gets dim, follow the wires back to the main fuse and battery,also test the voltage regulator and stator.
If it's when it gets brighter (real bright or normal bright?) test the voltage regulator and stator.
