Breakout Handlebar Swap
Old Nov 12, 2013 | 02:46 PM
JamieDTR's Avatar
JamieDTR
Default Breakout Handlebar Swap
So I'm working on putting a new set of bars on my 2014 Breakout, and am wondering about the wiring. Is there a plug somewhere to unplug that goes to the hand controls so I can pull the wires out of the bars? Not seeing anything....do I have to pull the gas tank off or just cut the wires?
Any help would be greatly appreciated.
Thanks.
Old Nov 12, 2013 | 04:32 PM
24v's Avatar
24v
There is a plug on either side of the frame under the gas tank for the hand controls and signals. There is also a plug under there for the speedo. Then you should be able to pull the wires out the ends of the bars. Do not cut any wires, it is not necessary.
Old Nov 12, 2013 | 10:43 PM
JamieDTR's Avatar
JamieDTR
Found em. Thanks.
Got everything mocked up, now need to figure out throttle cable and brake line lengths. Any recommendations on where to buy?
Old Nov 13, 2013 | 05:57 AM
24v's Avatar
24v
https://www.magnumshielding.com/
Old Oct 3, 2014 | 09:33 AM
jd_cincy's Avatar
jd_cincy
Can this be done without draining the tank and d/c the fuel lines?
Old Oct 3, 2014 | 12:27 PM
24v's Avatar
24v
Yes, just remove the bolt at the back of the tank, and the front. Lift the tank up and slide it back as much as you can. Beware of the clamps on the crossover line though. They will drag across the top of your front rocker box cover if you are not careful. I just wedged a piece of cardboard between them.
Blackjack1
Jul 27, 2018 07:16 AM
jackinthebox
Mar 18, 2010 07:32 PM
prouddawg
Apr 27, 2009 10:29 PM
fatboyfrankster
Apr 28, 2007 06:53 AM
vulhalla
Feb 21, 2006 02:19 PM
