softail shock absorbers
Old Aug 30, 2005 | 05:34 AM
jungleman's Avatar
jungleman
Default softail shock absorbers
I bought a lift to pick up my new softail and it looks like the shocks actually sit a little lower than the frame.
I don't think it enough to do any harm but I would rather not put pressure on the shocks.
I do not see a way around this problem. Any advise?
thanks, Jungleman
Old Aug 30, 2005 | 06:57 AM
jtfrog's Avatar
jtfrog
Default RE: softail shock absorbers
Maybe put some 2x4 parrallel to the frame?
Old Aug 30, 2005 | 10:28 AM
Taildraggerdave's Avatar
Taildraggerdave
I put the crossbar on the lift just in front of the shocks. Still picks the bike up level. I was concerned about the same thing.
Old Aug 30, 2005 | 11:44 AM
oldgeezer's Avatar
oldgeezer
I have a Craftsman lift. I position it just ahead of the shocks and it lifts my Standard just fine. I would never lift the bike at the shocks.
Old Aug 30, 2005 | 11:56 AM
Jezcruzen's Avatar
Jezcruzen
Ditto on all the above. Two by fours may be an option. I even think that HD sells "shims" to mount on the frame rails to add a little deapth. But, like the others said, I found that I can position the lift just in front of the shocks (with a full tank of gas - don't know what difference that makes) and the bike will lift level.
Old Sep 1, 2005 | 09:36 AM
ccmoran's Avatar
ccmoran
I use a Craftsman lift, I position it ahead of the shocks, just about wear the kick stand would be mounted and it lifts my FXSDTI great. I strongly advise lifting the bike back close the shocks; I have found that it leaves the bike a little unstable. There should also be some tie down's on frame of your lift that you can utilize to help stable your bike.
Old Sep 1, 2005 | 02:01 PM
wmiconi's Avatar
wmiconi
Always use a 4 by 4 as a safety measure. i went to the garage one morning and the craftsman jack was on the floor and the bike was sitting on the 4 by 4's.
DO IT!
Old Sep 1, 2005 | 04:49 PM
WildBill2566's Avatar
WildBill2566
Depends which end of the bike I want up. I have lifted on the shocks with no problem, but then again the lifting bar on my lift has been wrapped with old bicycle inner tubes so I guess when they compress some of the load is also taken on the frame.
WB
Old Sep 1, 2005 | 04:50 PM
rhinoevans's Avatar
rhinoevans
I can barely get the lift under the bike now, no way with added wood!
hoethree
Apr 8, 2012 11:57 AM
vonzoog
Sep 12, 2009 06:16 AM
snowmass
Apr 14, 2009 07:06 PM
Navychief
Jan 3, 2008 07:43 PM
Flying Pilgrim
May 2, 2006 04:29 PM
