Fuel gauge adjustment?
Old Jan 30, 2014 | 10:37 PM
F22 Junky's Avatar
F22 Junky
Default Fuel gauge adjustment?
I installed a 1.5" tank lift and lowered the rear of the bike 2", now my gauge doesn't read correctly. I go by my trip meter and know I have about 200 miles a tank, but I would like to adjust the float to match correctly if for no other reason that im bored and wanna tinker on my bike. anyone know a good way to go about this? Thanks.
and since this thread is worthless without pics....
tank lift before lowering bolts and after
Attached Thumbnails Fuel gauge adjustment?-img_0321.jpg   Fuel gauge adjustment?-image.jpg
Old Jan 31, 2014 | 03:51 AM
FroggyFatBoy's Avatar
FroggyFatBoy
the only way I know to adjust a fuel gauge reading is to remove the sending unit and slightly bend the float arm.
if its reading too low, bend the float arm down, too high, bend it up.
Old Jan 31, 2014 | 05:36 AM
jreichart's Avatar
jreichart
Yup, you can bend the arm to adjust how it reads. You'll need to remove the dash, then remove the fuel pump support plate. The fuel level sending unit is attached to the fuel pump assembly. It's a bit of a PITA to do the first time. Lots of YouTube videos on the removal, I'd recommend checking them out before diving in.
Old Jan 31, 2014 | 09:56 AM
Tyree's Avatar
Tyree
And the removal is easy compared to putting it back together.
Old Jan 31, 2014 | 10:03 AM
soft 02's Avatar
soft 02
I put 1 gallon of fuel in my empty tank and bent the arm till the low fuel light came on.
Old Jan 31, 2014 | 01:10 PM
F22 Junky's Avatar
F22 Junky
Sounds do-able, now, should I drain all the fuel from the tank and then put a gallon in?
Old Jan 31, 2014 | 01:37 PM
soft 02's Avatar
soft 02
Thats what I did.
FormerPointer
Electrical/Lighting/Alarm
May 11, 2015 09:29 AM
Glock Enthusiast
May 10, 2012 04:09 PM
Whale
Jun 21, 2010 05:24 AM
Nofear6372
Apr 12, 2006 02:09 AM
ultravista
Exhaust System Topics
Mar 2, 2006 11:23 AM
