Wont start
Old Mar 1, 2014 | 08:11 PM
drp.deluxe's Avatar
drp.deluxe
Stage I
Question Wont start
My 2008 fuel injected softail deluxe will not start, when I first turned on the ignition switch the lights came on, the fuel pump came on I turned on the run switch all seemed fine then the turn signal indicators flashed several time and the oil light started flashing and then nothing. Lights went out and seemed like battery was dead, tested battery with a volt meter and it was fine. Turned the ignition switch off then on acc and it seemed to come back to life. Tried again and all the same things happened. All the fuses are good, battery stays on a battery tender, started it and rode it 2 weeks ago, and all worked fine. Any body got any ideas.
Old Mar 2, 2014 | 08:22 AM
spydyr's Avatar
spydyr
Sounds like something wrong with your right side handlebar wiring. Possibly a shorted run/start switch or broken wire.
Old Mar 2, 2014 | 08:32 AM
RANGER73's Avatar
RANGER73
Sounds like your security system maybe.
Old Mar 2, 2014 | 08:35 AM
Iceman24's Avatar
Iceman24
When you say battery tested "fine" what was the reading...??
hvacgaspiping's Avatar
hvacgaspiping
Get out your owners manual and go through the key FOB setup. Your FOB battery may have died also.
Old Mar 2, 2014 | 08:47 AM
tmitchellof PG's Avatar
tmitchellof PG
The first and easiest thing you should do is disconnect and clean the battery cables. That will at the least eliminate that as being the problem.
Tom
Old Mar 2, 2014 | 09:03 AM
hdbob2006's Avatar
hdbob2006
Sounds like a security problem[like dead fob battery,but testing a battery with a volt meter tells you nothing about the condition of the battery. It needs to be Load tested.
Old Mar 2, 2014 | 09:19 AM
SanJuanRon's Avatar
SanJuanRon
Change your FOB battery. SJ Ron
Rsmil
Feb 6, 2019 03:30 AM
Conga
Jan 16, 2017 01:09 AM
Mr.Softy
11
May 22, 2015 12:58 PM
jblass
Dec 24, 2014 04:53 PM
