slipping clutch
Old Mar 21, 2014 | 07:06 PM
nickybandy's Avatar
nickybandy
Default slipping clutch
whats the best fix for a slipping clutch a heavy spring or just get the clutch plate with heavy counter weights
Old Mar 21, 2014 | 07:11 PM
Wild Card's Avatar
Wild Card
first...why is it slipping?
motor work?
is it adjusted properly?
how about its just time for new pack.
Old Mar 21, 2014 | 08:03 PM
nickybandy's Avatar
nickybandy
major motor work heads done new cams bigger piston an reworked throttle body
Old Mar 21, 2014 | 08:39 PM
Ink83's Avatar
Ink83
Good chance if it's already slipped a few times, the plates will be glazed
Old Mar 21, 2014 | 09:25 PM
bigblock59's Avatar
bigblock59
they should have put one in before your bike left the rack
Old Mar 22, 2014 | 06:39 AM
Blk and Chrome's Avatar
Blk and Chrome
The stock clutch won't handle much more than the stock HP. Depends on how much you have slipped it. It should have had a heavier spring put in it when the motor was done. You can always try one now and if it still slips then you need to repair the clutch
Wi_Duker
Jun 10, 2014 10:23 PM
FX4
May 24, 2014 09:51 AM
FLHXDAN
May 21, 2013 07:19 AM
police
Shovelhead
May 7, 2010 09:07 PM
CDN. RG
Nov 16, 2008 07:36 AM
