Stalling issue
Old Jun 1, 2014 | 05:46 AM
ttdriver's Avatar
ttdriver
Default Stalling issue
I have a 2008 FXSTC that has stalled 2 times recently when going slow. The motor seems to run fine but as I was slowing down it just kind of ran a little rough, idled real low and stalled. Both times I was coming to a stop and wasn't able to grab the throttle and rev it to see if it would come back. The motor is stock with the exception of Rush slip ons. It starts right back up and runs fine again. Any suggestions on what I should check?
Old Jun 1, 2014 | 10:21 AM
AU_Bob's Avatar
AU_Bob
Sounds like a pinched vent tube. Have you recently removed the gas tank?
Old Jun 1, 2014 | 10:30 AM
ttdriver's Avatar
ttdriver
Nope, nothing has been touched.
Old Jun 1, 2014 | 01:00 PM
AK47's Avatar
AK47
Try replacing speed sensor. I had the same issues and that seemed to solve it for me.
Old Jun 1, 2014 | 04:30 PM
jreichart's Avatar
jreichart
+1 on the speed sensor. Pay attention to the speedo and turn sigs as well. If the speedo seems a bit jumpy or inaccurate, or the sigs don't self cancel after a turn, then definitely the speed sensor. Might also just be dirty, it's on top of the trans right side of bike. Pop it off and see if the magnet is all gummed up with shavings.
Old Jun 1, 2014 | 05:16 PM
olongapo1's Avatar
olongapo1
Recently had the same situation. My problem was a faulty Idle Air Control Valve but the Vehicle Speed Sensor could also be the at fault.
Old Jun 6, 2014 | 05:49 PM
ttdriver's Avatar
ttdriver
Thanks for the replies. I'll check the speed sensor and go from there.
Old Jun 6, 2014 | 06:21 PM
drspencer's Avatar
drspencer
Had the same symptoms on my 2077 FXSTC.
Replaced IAC, and all kinds of other sensors, problem persisted.
Replaced VSS (vehicle speed sensor), problem fixed.
Joshus41
Sep 3, 2016 02:05 PM
donf610
Mar 20, 2011 08:58 AM
Dannell53
Nov 14, 2010 09:41 PM
harley_nova
Jun 20, 2009 03:06 PM
quin
Jul 15, 2008 11:10 AM
