Windshield help on 14 Slim
Old May 26, 2017 | 10:27 AM
jaxsoftail's Avatar
jaxsoftail
6th Gear
Hey Krazie8s, does the quarter fairing help with the buffering? I'm looking at adding something for those longer highway rides. Also, which quarter fairing is that?
BTW, ur bike looks badass!
Old May 26, 2017 | 11:21 AM
Paul On The Run's Avatar
Paul On The Run
Originally Posted by Krazie8s
OK, first time trying to post a pic in the forum, hope all goes well. I should have posted 4 pics which should provide you with good angles around the bike.
Not to hijack this thread but that looks damn slick. Love it.
Old May 26, 2017 | 11:27 AM
Paul On The Run
Now I will contribute. I used the HD windsplitter
It is true though, that this windshield works with the aux light setup. I don't have them nor did I want them so I read around and ending using some spacers from my local ace hardware. see link here talking about that.
I have since located the actual hardware needed to make it work which are part numbers 58270-02 (discontinued, but you can call your local HD dealer and they can probably locate them for you in the national database of parts. I found mine at Kent HD in Abilene, TX), then you need 2 spacers part # 5885
Old May 28, 2017 | 09:46 PM
FFeric's Avatar
FFeric
I went with the Long Rides shield on my Slim. It works well it just doesn't fit me. I am 5'7 on a good day and it is right in my line of sight.
Old May 29, 2017 | 05:31 AM
langwilliams's Avatar
langwilliams
FFeric that LRS looks good, the HD splitter would look better with black brackets.
Old May 29, 2017 | 07:23 AM
bfd70's Avatar
bfd70
I don't have much experience with different brands, but i did learn something about fitment the hard way this month. All of my online research suggested that the correct height for a windshield was around the bridge of your nose. Apparently this causes wind to flow over you reducing buffeting. What i learned was that in trying to determine what height would cause the shield to be at the bridge of your nose, don't sit on the bike with your feet on the floor while holding perfect posture. That is not the position you are in with your feet on forward controls and a bit of lazy slouch. The 1" lower this realistic position put be in caused the shield too to be directly in my line of sight. Drove me crazy in 10 miles. Need to go 2" shorter.
Brand wise I bought a memphis shades and am satisfied with the quality.
Old May 30, 2017 | 08:37 AM
Paul On The Run
That's an old picture. I powdercoated them two days after I got them. But yeah, they look way better in black
Old May 30, 2017 | 03:26 PM
langwilliams
Looks good Paul....HD should have saved you the trouble an offered it in black!
Old May 30, 2017 | 03:32 PM
Paul On The Run
Thanks. Yeah I know and still provide those damn brackets if you don't want to use aux lights. oh well. all figured out anyways.
Old May 31, 2017 | 09:13 AM
mpaquette's Avatar
mpaquette
Good luck. I'm on my 3rd windshield for my 2016 Slim S and it still does not fit right.
