Engine Noise Concern.........
Old Jul 7, 2014 | 03:42 PM
Memo7070's Avatar
Memo7070
Default Engine Noise Concern.........
Good day All, I have a concern on engine noise that I am hearing. I have a 06 Heritage Softail and I have been hearing the engine sound very loud on both sides( sounds like the valves??) I had a few friends listen to it and they told me that it was the chain inside. I'm a lil concerned with that, is it normal or can I possibly be sarting to get issues with it? Any and all information is appreciated. Also I did have some new SE 204 Cams installed maybe about 6-9 months ago. Thanks again
Memo
Old Jul 7, 2014 | 04:30 PM
UT-rckr's Avatar
UT-rckr
Miles? What does it sound like? A video would help so that we can hear it too
Old Jul 7, 2014 | 08:55 PM
Memo7070's Avatar
Memo7070
I will try to put a video up and it has just a hair over 34,000 miles
Old Jul 7, 2014 | 08:56 PM
Memo7070's Avatar
Memo7070
I will try to put a video up and it has just a hair over 34,000 miles. It sounds like I can hear the valves and rockers.
Old Jul 7, 2014 | 08:58 PM
Riffraff123's Avatar
Riffraff123
Look up threads about cam chain tensioners. Don't wait.
Old Jul 7, 2014 | 09:02 PM
nikonf8's Avatar
nikonf8
Default Noise
Have you ever had the cam tensioner's checked if they are crumbly apart you will have big problems I would not be riding the bike until I found out what's up
Old Jul 8, 2014 | 05:49 AM
martin1's Avatar
martin1
When the cams were installed they should have replaced the tensioners and inner bearings. Did they? Also, did you replace the lifters. Most people recommend replacing the lifters at 30K? I agree with Nikonf8. Dont ride the bike until you find out whats up. If something goes in the cam chest it could trash the engine and/or get you hurt.
Old Jul 8, 2014 | 11:32 AM
Memo7070's Avatar
Memo7070
I have recorded a video, can I txt it to someone to post for me? im not to computer literat. Cam tensioners and inner bearings were done when putting the new cams. The bike was warming up during the video. Thanks
Old Jul 8, 2014 | 12:59 PM
SGT Rock TN's Avatar
SGT Rock TN
how big is the file?
I am in the middle of the fix for my balancers going out. It comes from the bottom end of the engine. They are replacing the balancers, oil pump, cam plate, tensioners, etc. Should take 4 weeks.
Old Jul 8, 2014 | 01:51 PM
Memo7070's Avatar
Memo7070
Not sure on how big the file is, but I recorded about 1min 30 sec worth of video. I can txt it to you if you like?
