clutch problem.. quick question.
Old Oct 7, 2014 | 09:39 PM
Dog812's Avatar
Dog812
Default clutch problem.. quick question.
hey i just replaced my stator this weekend, Now i have everything together, and its running good. But i cant get my clutch adjusted properly.
Everything runs good until i am stopped in first gear.. It wants to creep forward , and wont let me shift out into neutral.
Do i need to do more then a 1/4 turn or less if this is happening??
Old Oct 7, 2014 | 09:43 PM
Dusty Bones's Avatar
Dusty Bones
If you crank the screw till it stops then back off a 1/4 turn it will still be too tight. Back it out, and as soon as you feel the tiniest bit of resistance then back it off a 1/4 turn. If you go past even a tiny bit past the resistance it will not be adjusted right.
Old Oct 8, 2014 | 04:38 AM
grbrown's Avatar
grbrown
Clutch adjustment can be a bit delicate to get just right! Make sure you un-adjust the cable, to introduce plenty of slack, then as per Dusty and reset the cable.
handirifle
Jun 26, 2019 11:35 AM
Weirbt
Jul 29, 2013 09:34 PM
TedMan
Nov 5, 2012 04:17 PM
EvilWayz
Ironhead
Aug 18, 2010 11:44 PM
midav
Mar 12, 2008 03:30 PM
