DARN THING WONT HOLD IDLE
Hello,just to give you some info on a bad idle situation and fouled spark plugs andseemed to be over rich (darn) 06 carb
Here is what was found:
1-not the plugs
2-not bad coil
3-carb set right
4-Here is your lucky winner (fuel petcock) remember theses are vacuumed controlled and that little dirty basterd was sucking raw fuel into the carb and upsetting its poor belly
5-Replaced with new one and that bad *** is running like a raped ape
6-So if you have a bad idle problem this is it
7- Ride Safe
1-not the plugs
2-not bad coil
3-carb set right
7- Ride Safe
