need some help
Old Oct 8, 2016 | 09:23 AM
Fastnfree44's Avatar
Fastnfree44
6th Gear
Default need some help
I bought a 77 sportster xlh as a starter and project bike. I figured it would be the best thing to do this way If something comes up I'll have a better understanding whats goin on. Has new starter, solenoid, relay, and breakers, new points and battery. I checked the wiring and followed the diagram to correct issues. (dude I got it from butchered alot of wiring) The after corrections seemed like it wanted to start, few lil fire ***** would come out of carb but battery would drain and fast. check grounds and it good, took strter off and passed bench test, took wire to positive and touched small stud on solenoid (saw another forum suggesting it) and the bike would crank but not start, im at a brick wall and need help or some direction. thanks in advance
Old Oct 8, 2016 | 04:27 PM
old schooler's Avatar
old schooler
You are a brave man,if you go to the classic section you will find ironheads,they will give you some good advise,when you get that up and running you will defiantly know a lot more about sportsters.
Old Oct 8, 2016 | 04:36 PM
Derf_'s Avatar
Derf_
Or may i suggest the http://xlforum.net/vbportal/modules/Jig/index.php?
Old Oct 9, 2016 | 09:12 AM
WVDevil's Avatar
WVDevil
Expect carb might need some work too. Agree with suggestion of the other forum, lots of guys there with older Sporties, really helpful folks.
Fastnfree44
General Topics/Tech Tips
Oct 20, 2016 05:17 PM
Fastnfree44
Oct 8, 2016 08:07 PM
2wheeltravelin
Jul 5, 2010 12:53 PM
superglazier
Jun 9, 2007 12:19 PM
rsnky
Jul 11, 2006 02:41 PM
