Disable alarms
Disable alarms
Hi folks,
I need to remove my battery to hand it over to a dealership for checking and I do know there is a sequence to disable the alarm before I remove it.
Would anyone know the UK codes and sequence for the alarm and how to reinstall that alarm when the new battery is back on??
The bike is a 2015 883 Iron.
Thanks for any help.
Best of
Wilf
Best of
Wilf
I know when I work on electrical or the battery, I turn on the ignition (not start it - just to disarm the alarm) then pull the main fuse. All power will go off. Then you can remove the battery without the siren going off. When you are ready to turn the bike back on, just do everything in reverse.
Received 2,189 Likes
I know when I work on electrical or the battery, I turn on the ignition (not start it - just to disarm the alarm) then pull the main fuse. All power will go off. Then you can remove the battery with the the siren going off. When you are ready to turn the bike back on, just to everything in reverse.
glenepower
Electrical/Lighting/Alarm
08-26-2018 08:07 AM
