Looking for a window bar..
Old Oct 12, 2017 | 09:27 AM
MikeRC's Avatar
MikeRC
Default Looking for a window bar..
Hey guys & girls I'm on a search for the right bar. I'm still running a stock Iron 883 bar and would like something a little more narrow. Would like a window/attack bar about 8 inches high with some pullback (no straight bar) that can be internally wired. I've found a few (Zombie Performance Clown Car Bar & Kenetic Lanesplitter Pullback) but both are pretty narrow at 24 inches. I've never run bars that narrow so can't comment on there comfort & control. Anybody here have either of those bars or does anyone know of another bar that would fit my needs?
Old Oct 13, 2017 | 10:31 AM
MikeRC's Avatar
MikeRC
Nobody here is running a window bar? There's got to be a 7-9" window bar that accepts internal wiring.
Old Aug 23, 2019 | 11:41 PM
Numinex's Avatar
Numinex
Talked with the head service writer. Said to bring it by next week for a tech to ride. My front tire was a bit low, and everything seems tight. But they said there should be some weight on the front tire, so that's where they will start. Did note how cranked up the rear shocks are (7 dots) said that could be part of it as well, but I'm 220 pounds current and that's how I've had to set them to prevent bottoming out on everything and every bump. Shocks drop about 3/4 of an inch with me sitting on it and a nice heafty bounce just barely bottoms them now. Using the zip tie method to measure shock travel. If it is rear shock I will probably just save up for some progressives. Maybe an inch taller.
Old Aug 24, 2019 | 02:14 AM
Midpegs's Avatar
Midpegs
I think you have got the wrong thread here . This was about Window Bars , whatever they are .
Old Aug 24, 2019 | 02:45 AM
Numinex's Avatar
Numinex
Yep my bad. Some how I clicked on my thread and got this one. Wondered where my post went.
Old Aug 24, 2019 | 05:56 PM
dave the welder's Avatar
dave the welder
Whats a "window bar"? Is this something you look thru and see the speedo? Or you pull up to the bar and order drinks thru a window???
Old Aug 24, 2019 | 07:12 PM
hdbob2006's Avatar
hdbob2006
Drive thru liquor store?
Old Aug 25, 2019 | 07:02 PM
dave the welder
That makes sense!
BuzzCap7
"The Florida Crew"
23
Feb 7, 2026 07:37 PM
ChickinOnaChain
May 1, 2014 04:04 PM
ANESTHESIA
Jan 21, 2011 03:45 PM
eisterd
The General Motorcycle Forum
31
Apr 25, 2010 03:10 PM
Superglide 04
Jan 22, 2008 12:49 PM
