My sporty would not start this morning.The starter goes,but the drive doesn't engage.I've got 26,000 Kms on my 06 1200c.Any body else have this problem.[:@]
I've not had that problem with my Harley but did have it with a Honda CB-750. Try putting it in gear and rocking it forwards and backwards and then try to start it again. Something could be out of whack with the starter teeth alignment...
Your Sportster has a Denso starter, if the starter contracts are worn, you will only hear a click or no sound when you crank, it is repairable, PM me ok. I would suggest you to check the ground first, common problem, it could also be the starter pinion drive.
I misread your post, if the starter turns, the solenoid is working, that starter uses a solenoid to push the plunger out, at the same time it completes the starter motor circuit. Sounds like the pinion gear is gone.
