What's this for ?
Old 07-11-2019, 09:59 AM
Midpegs's Avatar
Midpegs
Midpegs is offline
Received 1,115 Likes on 629 Posts
Default What's this for ?
Just cleaning the muck off the top of my oil tank so I moved the ECU out if the way only to discover this rather complicated looking grey connector . There's nothing inside it and it doesn't connect to anything . It has just one red wire going into it . Any answers will be gratefully received.
Old 07-11-2019, 11:29 AM
apache snow's Avatar
apache snow
apache snow is offline
That could be the resister for your fuel gage light. If not I don't know.
Old 07-11-2019, 11:37 AM
Andy from Sandy's Avatar
Andy from Sandy
Andy from Sandy is offline
Received 3,746 Likes on 2,407 Posts
Resistor pack will have at least 2 wires going to it but I still can't help with what you have there.
Old 07-11-2019, 12:27 PM
apache snow
Well there it is next to the fuel sensor but still don't know
Old 07-11-2019, 01:31 PM
Midpegs's Avatar
Midpegs
Midpegs is offline
If you open it up , it's just empty . It's got to be for adding some auxiliary equipment but why the one red wire ? Whatever it is it would have to be earthed and without a switch in the circuit it would be functioning at all times . Further research is called for .
Old 07-11-2019, 01:48 PM
Midpegs's Avatar
Midpegs
Midpegs is offline
Right , sorted . It's called the B+ connector and it is intended for connecting auxiliary equipment as I had previously suggested . There are dozens of references to it with full explanations to be found right here on this very forum . It isn't exclusive to Sportsters either.
Lwood10 (07-11-2019)
Old 07-11-2019, 08:22 PM
barneyboy's Avatar
barneyboy
barneyboy is online now
Received 2,629 Likes on 1,533 Posts
Be mindful when connecting accessories to the B+ (battery positive) connector. Even though the connector is protected by the 30 amp maxi fuse, the connector is rated @ 9 amps max, and will melt long before blowing the maxi fuse if overloaded.
Old 07-12-2019, 12:41 PM
DeplorableOne's Avatar
DeplorableOne
DeplorableOne is offline
Exactly, make sure you fuse whatever you connect after this connector. I would imagine 30 amps would easily melt the insulation off that tiny wire.
Toneaero
04-30-2023 04:29 PM
jcolleymx
Electrical/Lighting/Alarm
07-29-2021 04:02 PM
Michael R Moore
02-08-2019 02:39 PM
TLD
Harley-Davidson Street
04-06-2017 04:33 PM
VinnySem
03-21-2011 10:07 AM
Quick Reply: What's this for ?
