I rode from Alabama to Ohio last week to help my sister drive back fo Alabama. When I got to her house I put my 2005 1200 XLC up on a utility trailer for the drive back. As I rode up the ramp the frame pin that the jiffy stand hooks to hit the trailer hinge and broke off. I didn't know it broke off and thought the spring got caught and came unhooked. Did this ever happen to anyone here? Can this be fixed with a simple weld of a metal with a recessed area? I would appreciate your recommendations. I am the original owner of this bike and don't trailer it. I finally had time to compare the bike to the service manual and realized what i had done this evening . You can see the pin in the Harley 2005 service manual diagram inside the frame near the crossbar between the two number 2s
I finally had time to compare the bike to the service manual and realized what i had done this evening.
It really isn't very clear what you have broken. If you have broken the actual jiffy stand mount from the bike frame then I think a good welder would be able to repair it for you.
I would also think that to hit that part that hard to break the weld might also have damaged the frame a little.
On my bike the part that is lowest to the ground is the bit that the spring locates in. I have hit that twice now on sleeping policeman.
If the pin..just get new parts and ensure the cotter pin is installed as the parts diagram.
The clip that holds the pin in is described as single use in the manual.
The part that broke off was, for lack of a better word, is the tip of the pencil diameter sized place the spring hooks to pin the frame. One end of the spring hooks to the Jiffystand and the end facing the front of the bike hooked in the recessed area of the pin. It is like the bottom 1/4 inch of that piece of metal snapped off.
Oh the spring hook pin... (NOT the clevis pin... yeah you'll need to get piece welded back onto the frame to fix that. Any decent welding shop should be able to fabricate a new pin and TIG it in place for you.
