Need Help
Old Jul 12, 2007 | 07:33 PM
pjweber's Avatar
pjweber
Default Need Help
My bike: 2006 1200C, 20K miles
Stock AC & pipes (Carb was richened up a bit 1 month ago)
Coming home this afternoon on the freeway 70 MPH and felt a slight hesitation in power 2x very quickly.
I exited the freeway, cruising at 45 MPH and lost all electrical for a few seconds lights were flashing on/off but the motor was still running. About a mile later the same thing happened but this time the motor died. I pulled into a parking lot and shut down. Bike started right back up and the hesitation happened a couple more times before I arrived home.
Thinks I have checked so far:
Battery connections
Pulled the plugs-looked OK
What else to check? Thanks in advanced for any help or tips
Old Jul 12, 2007 | 07:54 PM
rwjjr's Avatar
rwjjr
Default RE: Need Help
voltage regulater???Mine went out at 9k
Old Jul 12, 2007 | 08:43 PM
Wolhar's Avatar
Wolhar
ORIGINAL: rwjjr
Yea,, that and check the Thread Pinned at the top of the page, and pull up the Diagnostic Codes.
Old Jul 12, 2007 | 08:54 PM
Dallastx's Avatar
Dallastx
Yeah check it out! Stock pipes? Interesting.
Old Jul 12, 2007 | 09:20 PM
pjweber's Avatar
pjweber
ORIGINAL: ******
ORIGINAL: rwjjr
I went through the diag code check, no codes to report.
How would I know if the voltage reg is going bad/bad?
Old Jul 12, 2007 | 09:54 PM
SportyBoiler's Avatar
SportyBoiler
2nd Gear
You indicated that you checked the battery connections, but did you also check the ground wire bolted to the bottom of the frame in front of the battery? I had a simlar issue and this connection was loose. Tightened it up-no problems in over a year.
Old Jul 12, 2007 | 10:22 PM
pjweber's Avatar
pjweber
ORIGINAL: SportyBoiler
Yes, that connection is tight also.
Old Jul 14, 2007 | 08:42 PM
pjweber's Avatar
pjweber
Default RE: Need Help-UPDATE
I took a ride this morning to see if I was still having problems. Rode for about 30 minutes with no problems, ready to head home and the speedo died. Bike was running fine otherwise.
Got home and pulled the VSS and had a corroded pin, I was going to just try to clean it up but I decided to replace it. I didn't want to risk the corrosion to migrate into the harness connector.
Went for another ride this afternoon and everything seemed OK.
P.S.- I had pulled the connector for the oil pressure switch and it had some grime in it, cleaned that up to, may have contributed to the hesitation I experienced maybe...
shane_moto33
Jun 13, 2015 03:25 PM
rwb1
Aug 28, 2012 06:17 PM
jwyrem
Nov 20, 2011 05:23 PM
IlDuce
EVO
21
Jun 22, 2009 12:49 PM
KenM
Oct 18, 2005 07:26 PM
