Backfire Help
Old Jul 16, 2007 | 01:00 PM
Avioza's Avatar
Avioza
5th Gear
Default Backfire Help
I have a 2003 Sportster 1200c that is getting a backfire up through the carb. I have had the backfire since I bought the bike and it is starting to burn the ring connected to the rubber booton the carb.
The backfire happens when throttling down, or slowing the engine coming into town zone etc. Otherwise the bike runs great! Sounds perfectly normal and all the power I need accelerating and holding speed.
I am open to any ideas before I take it to a dealer and get a big bill.
Some pertinent information:
-Bike was purchased new and sat for ~3 years before I bought it
-I have put in a dynajet kit
-Installed performance air breather
-There is a lag before the bike throttles down. Not much but noticable. (Likely not related to backfire but just in case: was backfiring before this problem started)
-Running 87 Octane
It has been suggested by others that:
a) Sticky Valve
b) Timing (I thought this was unlikely do to great performance)
At this point I have my shop manual and will try and check timing myself ifI can borrow a timing light, but I would appreciate any pointers please.
Thanks in advance!
Old Jul 16, 2007 | 08:01 PM
cHarley's Avatar
cHarley
Default RE: Backfire Help
First, the 1200 needs 91 or higher octane. How did you determine the jet sizes when you installed the Dynojet kit? Your symptoms indicate you may still be running lean.
Old Jul 17, 2007 | 05:15 PM
98XL1200C's Avatar
98XL1200C
Yea..I always use 91 or higher octane. Dealer installed a 27170 - 89
slow jet........
tabogon
Sep 13, 2013 07:01 PM
Davemac122383
Sep 11, 2012 06:04 PM
Cohiba_Joe
Exhaust System Topics
May 31, 2012 08:10 PM
dkharley
Apr 23, 2010 07:59 AM
EyernHeadHD
Ironhead
Jun 3, 2008 08:48 PM
