primary chain adjustment without moving the wheel
Doubt you are even going to find any difference. Please report back.
Does not a Sporty go by backoff on both clutch and chain tension?
The chain you just turn the adjuster until the required up down movement (play) is reached. Then stop and tighten lock nut.
The clutch sees you turn the screw out to feel tightness and then turn it in a 1/4 turn.
Jackie Paper (12-07-2020)
On my 2013 XL1200C I have adjusted the Primary a few times now that I have 30K plus miles and haven't turned the wheel to find loose or tight spots, BECAUSE I couldn't!
Even with the plugs out and in a higher gear I can barely turn the rear wheel, it just doesn't spin, it chugs LOL.
I must be doing something wrong, can any of you guys turn the rear wheel when in gear ??
BTW: Yes of course the rear wheel is off the ground
benjamin lorenzo (12-07-2020)
Have you tried eating more spinach? Put some meat on those chicken wings!!!
John
back again (12-08-2020)
