Clearing error codes
Old Jul 9, 2021 | 09:13 AM
MikeLaPlaya's Avatar
MikeLaPlaya
Default Clearing error codes
Hi Guys Iron 2014 .
Getting some error codes , Cleared the ECM codes but there is an error in what looks like BCM ON THE BIKE display.
I cannot clear it , i have also changed the battery , so i disconnected the battery obviously. That did not help.
I went into the error codes on the Power Vision and cleared codes , cleared the ECM but they come back when i start.
They are saying the sensors are open .
I have put on the power vision Target tune , so new sensors , wide band O2 , preparing for the 1275 upgrade.
All i could find was to reset the ECM was in the end you had to disconnect everything . So i did.
Is there another way , cleared codes using Power vision , also using the bikes clear function but that leaves the BCM code there even when it says cleared.
Also used a FP3 to try and clear the error codes . No luck there as well..
Is there another way to reset the ECM and BCM , i think that is what the display shows.
EG can i send a micro charge of 12 volts to reset ? Going to be taking photos of the PV error codes and the speedo dial error codes.
All electrical work was done by an auto electrician .NOT ME- I know nothing .
Old Jul 9, 2021 | 09:30 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
If a code returns immediately at switch on or won't clear then you have a hard fault that needs attention I would think.
What is the code(s)?
Old Jul 10, 2021 | 06:59 AM
MikeLaPlaya
YOU WON'T BELIEVE THIS , the auto electrician put the connector inside the cover, i did not have anything to cut the zip ties
holding on the battery cover . Will up date today ,
Jerry Harshman Jr.
Mar 30, 2020 12:28 PM
tj66
Jun 16, 2016 10:08 PM
Big Dave
Apr 3, 2016 02:12 PM
inkedup7
May 28, 2015 02:08 PM
jesled
Apr 15, 2008 09:29 PM
