P0141 error code on ECM (Iron 883@2022)
Good day Sportster riders,
I own a 2022 Iron 883 that has clocked 1520 kms as on date and first service is due. A while ago during my weekly short ride, I noticed my Engine light continuously on, while the Bike was running. I checked ECM and the error code found was P0141, indicating damaged wiring or loose wiring. There was no damaged wiring found upon visual inspection and so loose wiring or minor corrosion in wiring terminals is suspected. Also this ECM light went on in the middle of my ride and I did not have trouble getting back home.
I shall be grateful for any Troubleshooting tips you can provide me in this regard. Initially, it appears to be a straightforward solution.
Thank you
Thank you
96hugger (04-27-2024)
Okie883custom
10-16-2018 02:01 PM
