Engine light came on after 10k miles 2016 883 iron
Old Oct 16, 2018 | 11:04 AM
Okie883custom's Avatar
Okie883custom
Stage II
Default Engine light came on after 10k miles 2016 883 iron
I recently did the custom paint on my 2016 883 iron and it just turned over 10k miles. The weather changed to 40s and 50s with a bit of rain so she sat for about 4 days. Ran great for about 2 weeks till i parked fir the weather. Service engine light came on and it sputters and loss of power. Checked oil and its ready for the 10k service which i was gonna do the primary and oil. Did the dianostic check and it isnt saying the psspt like normal. It goes diagnostic and then i hit the button to scroll and it goes to ecm Y, bcm Y, and speedo N. Why is it not showing a code?
Old Oct 16, 2018 | 11:20 AM
nevil's Avatar
nevil
Check your battery and ground cable connections. Sounds like something is loose or dirty.
Old Oct 16, 2018 | 01:52 PM
Okie883custom
Stage II
Default Already did. Its throwing code P0031 ecm code
P0031 ecm code is whats wrong. Checked every pig tail and both battery cables already before i made post
Old Oct 16, 2018 | 02:01 PM
nevil's Avatar
nevil
You didn't say anything about that code. P0031 is front HO2S low/open. So check the wiring on your O2 sensor.
I know you said you checked both battery cables but did you look at the negative cable where it grounds to the frame?
David Jeremy Dickson
General Topics/Tech Tips
Aug 13, 2018 03:55 PM
jnazir
May 5, 2017 07:24 AM
ironlink
Mar 1, 2015 08:19 PM
CajunIron
Nov 19, 2013 01:25 PM
ghost0704
Sep 29, 2011 01:37 PM
