Trouble Codes
Old Aug 13, 2018 | 02:43 PM
David Jeremy Dickson's Avatar
Stage I
Default Trouble Codes
A good friend has a Sportster 883 2004 model. After she warms up, Operating temperature or so if you stopped at a light for instance, when you tried to take off there would be no response from throttle. Just sputter and backfire a little. I retrieved the codes just a minute ago and got a P0373 and P0374. I think these are CKP codes but I'm curious what the common fix is. Is the sensor toast typically? Also have a high and low voltage code(s) P0562 and P0563. Any help would be greatly appreciated.
Old Aug 13, 2018 | 03:55 PM
mmesa005's Avatar
mmesa005
Start by checking the battery. You can use the proceedure in the service manual or take it to auto zone or similar and they can test it. Also, check the battery cables at both ends to ensure they are not just connected but also there are no other problems such as corrision, cuts, partial breaks in the cable.
Chucky55
Sep 5, 2016 03:20 PM
Malapropos
Aug 11, 2016 12:23 PM
gary1hd
Oct 5, 2012 11:07 AM
Big Peter
Jan 16, 2010 04:33 PM
pococj
Jul 8, 2009 05:33 PM
