Tachometer
Old Jan 23, 2026 | 08:05 AM
WKNDS's Avatar
WKNDS
You'll have to define what is "not too expensive". IMHO, anything you find
under ~$100 is probably not going to work well. I have never used this
version below from Bikers Choice, but it is about as "cheap" as I would go...
https://bikers-choice.com/bikers-cho...2-inch-493374/
good luck,
T.
Old Jan 23, 2026 | 09:31 AM
Leonides's Avatar
Leonides
2013 sportster custom 1200cc.
Old Jan 24, 2026 | 09:43 PM
hammer6315's Avatar
hammer6315
Originally Posted by OCSpringer
I use a clip on tach to set the idle and the 2000i has a rev limiter. I call that good enough for me, but I have concidered a small shift light so I know when I'm aproaching the rev limiter.
Doesn't the power 'nose over' before the rev limiter?
Old Jan 24, 2026 | 11:40 PM
OCSpringer's Avatar
OCSpringer
Dunno I've never hit it. I have the rev limit set at 6500 rpm. From the dyno sheets I have seen for the 100hp package it seems to flatten out in the mid 6000's. This thread actually got me thinking about shift lights again and I found a new dyna setup for efi HD on eBay for super cheap that I am going to see if I can get to work. Looking at the wiring diagram for the efi coil it seems like it should work if I just cut off the plug and wire it directly to the coil, or preferably the tach wire from the 2000i. I would like to set up a light at 4500 or 5000 rpm to give a reference point. We'll see if it works out. I would prefer a light to a tach as I never look at a tach normally except for tuning (idle) or when I'm really getting on the throttle, but at that point the last thing I really want to do is take my eyes off the road.
Old Jan 25, 2026 | 06:46 AM
WKNDS's Avatar
WKNDS
...snip...
...snip....
The Dyna shift light pictures I have seen online make it appear rather large (diameter). Would it "get in the way"
or otherwise be obtrusive ? I have the AutoMeter Quick-Lite in my "project" Trans Am and I like it since it is
fairly small and not too gaudy like some of those tach's with the shift light attached to them. I took the sticker
off of it so it is even less noticeable...
https://www.summitracing.com/parts/atm-5330
Just an opinion,
T.
Old Jan 25, 2026 | 07:08 AM
OCSpringer's Avatar
OCSpringer
Just an opinion,
T.
I'm not sure as I have not seen it yet, but my understanding is it is one of the smaller ones and it definitely seems smaller than the one in the link provided. Where I plan to put it it won't really be visible to anyone but the rider, me. I found the pingel handlebar mount NIB for it as well for 1/2 price. At $165 for a $500 setup (shift minder module ($250) + light ($160) + bracket ($90)) it was worth experimenting with. If i don't think it will work out I should be able to resell it at that price.
Old Jan 25, 2026 | 07:41 AM
WKNDS's Avatar
WKNDS
So back to the original "add a tach", I have read a few complains about
the Baron handlebar mounted tach's. These may not be available anymore
and are not "cheap" either. I do not recommend anything that I have not used,
so if you go with this one, report back & let us know how it worked out....
For example;
https://www.jpcycles.com/product/bar...let-tachometer
hth,
T.
Old Jan 27, 2026 | 07:40 PM
Madnss's Avatar
Madnss
Tachs and shift lights, I’ll take both for a $1000 Alex 😁
Old Jan 28, 2026 | 03:24 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
I have in effect a shift light in my car. It suggests which gear I can be in or ought to change down to.
Old Jan 28, 2026 | 07:04 AM
Kenny94945's Avatar
Kenny94945
As a heads up, some of these tachs needs a module (as I recall, another $50+ of parts).
If no module the tachs seems to read 1/2 the actual rpm.
There is also bracket you'll need to fabricate depending on your OCD of the tach's orientation.
As for cheap, I'd predict $200 will be your budget with new aftermarket parts.
If using HD parts, well, I'd up the budget to $500.
Could be junk yard searches will be the low-cost option.
Good luck.
