Check for them on sites like J&P, Dennin Kirk and such. Easy connecting, but suspect apperance and sub-par quality, I fear. I spent major bucks and got the factory option Harley original and am happy with it on my '08.
I use a clip on tach to set the idle and the 2000i has a rev limiter. I call that good enough for me, but I have concidered a small shift light so I know when I'm aproaching the rev limiter.
I suppose it depends on what you want out of the part you fit with appearance to the rest of the bike.
I went with the HD offering as it doesn't detract from the rest of what I have and is a single unit showing analogue tachometer and digital everything else. Plus with the costly extra bit I also get a fuel gauge.
Possibly best for bikes '08 and newer due to changes to what's programmed in the ECM.
70900100C - 4 in. Combination Digital Speedometer/Analog Tachometer (HDI)
70900475 - Domestic
61200008A - Fuel Sending Unit
70900274 - Combination Digital Speedometer/Analog Tachometer for '04 to '13 Sportsters
The USA model can display miles or kilometres so I really don't know what the difference is between 70900475 and 70900100C but these are the ones for 2014 and newer.
