Secret Combination?
Old Jan 5, 2006 | 03:01 PM
ronn39's Avatar
ronn39
Default RE: Secret Combination?
I can't help you with that one alexcue. Mine came on the bike and I don't have the original to compare. There is a rubber gasket around the cover, but that's all it is. If you find out what this "adapter" is, I'd be interested in knowing that myself.
Old Jan 5, 2006 | 04:19 PM
alexcue's Avatar
alexcue
ronn39, ya that's kinda the same boat I'm in. The bike already had the Stage 1 done to it, so I don't know how it should be "stock".
btw, i really like the looks of that cover, and i see online the other chrome parts are pretty shnazzy!
God knows, this is going to be an expensive hobby...
Old Feb 16, 2007 | 05:01 PM
britbiker's Avatar
britbiker
OK. Thanks for the info on how to get the Swingback cover off, that was mystifying me!! The adapter that you guys are talking about is only required if the Stage 1 upgrade has been done on the bike. If no Stage 1 has been done then you do not need the adapter & the Swingback cover is just a swap fit.
UPDATED INFO: If your bike is fitted with the Stage 1 Screamin Eagle High Flow Air Cleaner kit # 29042-04A then you need the adapter kit # 29848-04 to fit the Swingback cover. Hope that helps!
Old Feb 16, 2007 | 07:07 PM
jakedog's Avatar
jakedog
Nice looking scoot. I also have the 04' 1200 but is the roadster..... Mine is the same Teal color as yours which is the ony other one I've seen.
Old Feb 17, 2007 | 02:13 PM
SportyPig's Avatar
SportyPig
I had this air cleaner trim on my bike with the stock air cleaner. When I installed the Screamin Eagle air cleaner, I had to get slightly longer hex head bolts to re-install the trim. I suspect that's what the difference is on the swingback cover also.
ATM983
Milwaukee Eight (M8)
Jun 5, 2019 01:47 PM
Nick412
Engine Mechanical Topics
Jan 15, 2015 03:40 PM
cameraboy
Oct 18, 2011 06:09 AM
Donefarmin
Mar 7, 2010 01:28 PM
Abnmarine
Aug 16, 2006 11:33 PM
