1200c riser and apes question
Old May 12, 2008 | 10:47 PM
chromedome's Avatar
chromedome
Default 1200c riser and apes question
Son is thinking of puttingapes on his 08 1200c (I seem to be his research and development department). Looking at the speedo housing top clamp set up it would seem that you are kind of linited to the height of the risers if you use other than stock risers. Seems like if you go too low in height that the bottom of the speedo housing would hit the tank. If anyone has used other than stock risers I'd appreciate knowing what you used to solve this problem. Heck... I'm just going by photos... he has the bike in Oregon.. and I may be wrong about this whole problem.
Old May 12, 2008 | 10:51 PM
6o66er's Avatar
6o66er
Default RE: 1200c riser and apes question
3" straight risers should work perfect. The speedo should still clear the tank just fine. If not, he could always just flip the risers around and have the speedo up top.
woodstock964gt3
Oct 18, 2017 10:32 PM
doc_green35
Mar 30, 2014 10:30 AM
JerryDinMD
Mar 16, 2012 06:14 PM
Scottybob
Jul 7, 2011 07:56 PM
trailey97
May 6, 2009 03:53 PM
