Short risers for a breakout?
Old Oct 18, 2017 | 08:18 AM
woodstock964gt3's Avatar
woodstock964gt3
6th Gear
Default Short risers for a breakout?
Hello all,
I searched the forums for info about short risers for a breakout and all I found were guys going the other way and/or thunder bike's risers.
Having stupid long arms and just liking the way the TB risers look on my bike I wanted to go the shorter route. I'd pull the trigger on the TB risers, but $300+ shipped is just too much to justify even for cycle parts!
Anyone have any other idea's?
Thanks in advance.
ck
Old Oct 18, 2017 | 07:57 PM
DrPlastic's Avatar
DrPlastic
I measured mine and if you go any shorter the speedo housing will contact the tank. Now if you go with a straight riser instead of the OEM curved ones it may give you the distance you desire. Unless you can modify the speedo and flip it around that may work but I looked at the indicator light panel and it would be tough to flip it around the other way.
Old Oct 18, 2017 | 08:19 PM
woodstock964gt3
6th Gear
Yep, they def. have to be straight. The Thunderbike ones are only about 1.5" long and the speedo clears the tank!
I was trying to find someone in the US that made a similar product.
Old Oct 18, 2017 | 10:17 PM
UHDhog's Avatar
UHDhog
The 2014 CVO Breakout risers are what you're looking for.
Old Oct 18, 2017 | 10:32 PM
Odinbreakout9's Avatar
Odinbreakout9
If you do the CVO risers, you have to change the top clamp also (a little over $300 total).
You can try these...
https://www.dark-parts.com/product/f...akout/?lang=en
or...
https://www.dark-parts.com/product/s...akout/?lang=en
barry-richards
Nov 12, 2016 02:43 PM
07superG
Sep 20, 2016 04:49 PM
ryranee
Aug 17, 2013 07:23 PM
Shark46
Oct 22, 2008 02:09 PM
HANDLER
Jun 6, 2007 05:14 PM
