Risers/Pull Back Question
Old Mar 16, 2012 | 03:23 PM
JerryDinMD's Avatar
JerryDinMD
Default Risers/Pull Back Question
Thinking of getting a set of pull-backs-the ones i see are anywhere from 2-6" rise and only 1-3" pull back. Is that enough of a pull back to notice? I need some kind of pull back-im reaching too much on the bars-but would that small of an amount help? --thanks
Old Mar 16, 2012 | 06:14 PM
PaDutch's Avatar
PaDutch
The 2.5" pullback risers from Drag Specialities worked for me. I was having shoulder and neck problems riding my '07 FXD with stock (short) risers. I wanted to keep the buckhorns, and not have to replace any cables or lengthen wires. The 2.5" risers gave me just the right reach, and worked with stock cables and wires. But... The FXD speedometer is mounted to the top clamp, which is made for a horizontal mounting to the stock risers and the speedo has a 35 degree up angle. The pullback risers also angle back, so the speedo wound up sticking nearly straight up when using the stock top clamp and speedo housing. The solution I chose is at https://www.hdforums.com/forum/dyna-...stone-fix.html My wife never did find out how much I paid to reposition the speedo..... If your speedo is not mounted to the top clamp, won't be an issue.
doc_green35
Mar 30, 2014 10:30 AM
HDDyna2006
Nov 11, 2009 07:42 PM
Shark46
Oct 22, 2008 02:09 PM
chromedome
May 12, 2008 10:51 PM
KeithB
Nov 6, 2006 08:44 PM
