starting problems
Old Mar 2, 2006 | 07:03 PM
jasper's Avatar
jasper
2nd Gear
Default starting problems
Hi from the UK, I have a 1999 XL53C that has suddenly stopped starting!(if that makes sense). When I hit the start button the engine runs for a few secounds and the just dies .
I have checked fuel/plugs/air filter/battery-etc no joy getting slightly desperate anyone out-there got any ideas ? Jasper :-)
Old Mar 2, 2006 | 07:32 PM
brohrs's Avatar
brohrs
Default RE: starting problems
Check for fuel problem like plugged petcock ,sludge in tank. Is the gas old at all? I dont think electrical would act like that, it just wouldnt start at all.
Old Mar 2, 2006 | 11:15 PM
molsenice's Avatar
molsenice
Ceck this on the carb
on mine, it's an 06 but the 05 had it as well, not sure if they are on yours, there is a vacume hose that goes to the back of the petcock - darn near imposible to see and easily missed. It is a vacume hose
If this is off, the valve will not let fuel flow - check if you have one and if it is hooked up and has no holes in it - it is about the same diamiter as an ink supply in a ball point pen - good luck
Old Mar 3, 2006 | 10:14 AM
bensonjv's Avatar
bensonjv
Here's a link to a thread with pics of that hose molsenice is talking about.
Old Mar 3, 2006 | 01:35 PM
molsenice's Avatar
molsenice
ORIGINAL: bensonjv
Good god I remember this thread - and then last month, had the same problem as you did bensonjv - when I forgot to reattach this very same hose after putting the tank back on (did a bar change over)[sm=headbang.gif]
Old Mar 3, 2006 | 10:52 PM
bensonjv's Avatar
bensonjv
[sm=laughat.gif]
Sorry. Aint it funny how the simple stuff gets us the most?!
Old Mar 5, 2006 | 08:50 AM
jasper's Avatar
jasper
2nd Gear
HI again from the UK,
Still no joy Ive replaced the vacuum pipe (old one perished/split), cleaned out fuel tank sludge etc, cleaned float bowl of carb,even checked choke(enricher)action.
Baffled by it all...Jasper /;-(
Old Mar 5, 2006 | 09:11 AM
Thumper26's Avatar
Thumper26
Did you take the float out and put it in a glass of gas to see if it has a pinhole leak?
Thumper26
Old Mar 5, 2006 | 12:20 PM
baggersport's Avatar
baggersport
Still sound like it may be fuel. Remove the fuel line from the petcock or carb. (whichever is easiest), apply vacuum to the fitting on the petcock or you could crank the engine with the starter, does the fuel flow????? Careful not to spill the fuel, use a hose directed to a catch can.
Old Mar 5, 2006 | 03:35 PM
jasper's Avatar
jasper
2nd Gear
Hello agaiin ,
No holes in float, vacuum pipe/fuel flow fine..Jasper :-0
