2005 custom electrical problem
Old Jul 17, 2008 | 03:10 PM
wilcher's Avatar
wilcher
Default 2005 custom electrical problem
My 2005 1200 custom has an electrical issue.&nbsp\\; Key in ACC position bike has juice.&nbsp\\; In On position no juice.&nbsp\\; Pulled batt, load test, no dead cell with 10.9 Volts.&nbsp\\; Hooked up to charger, checked all connections, cleaned connections at starter and battery, checked all fuses.&nbsp\\; Is it simply too low on the voltage?&nbsp\\; Why would it show power in the ACC but not On position?&nbsp\\;
Old Jul 17, 2008 | 03:20 PM
WVHogRider's Avatar
WVHogRider
Default RE: 2005 custom electrical problem
Key/Ignition switch could have went bad, or loose wire to it...[&:]
cHarley's Avatar
cHarley
10.9 is to low. The battery should read between 12-12.5 vdc with no load. The additional amp load of the lights when you switch to the ON position is likely causing the voltage to drop to nothing. Charge or replace the battery.
Old Jul 17, 2008 | 03:21 PM
WVHogRider's Avatar
WVHogRider
ORIGINAL: cHarley
I was thinkin' that it should have been around 12.?, but couldn't remember right off hand.
Old Jul 17, 2008 | 07:53 PM
wilcher's Avatar
wilcher
charged the batt and still nothing, now sporadic elec power in ACC position, nothing in ON.&nbsp\\; What now?
Old Jul 17, 2008 | 11:22 PM
jdvorchak's Avatar
jdvorchak
after you charged it what was the voltage. I'd say this is probably the original battery and it is shorted. 10.9 volts indicates that you have 2 shorted (dead) cells. I doubt that charging it will do anything meaninful. A good battery discharged should read about 12.6 volts with no load. Charged it should read almost 13 or slightly above with no load. You got 3 good years out of that battery, time for a replacement.
Old Jul 18, 2008 | 10:32 AM
HOTLAP's Avatar
HOTLAP
Yes it sounds like the battery, only other thing you might try is some electrical contact cleaner spray in the ignition switch, may have some soap scum or corrosion on the contacts in there.
Old Jul 18, 2008 | 05:11 PM
wilcher's Avatar
wilcher
It was the battery.&nbsp\\; New one fired right up.&nbsp\\; Two hours of troubleshooting for a 10 minute job.&nbsp\\; KISS (keep it simple stupid)
Old Jul 18, 2008 | 05:44 PM
HOTLAP's Avatar
HOTLAP
Glad you got it sorted, and thanks for telling us, a lot of times we never hear back as to what it was after all.
Old Jul 19, 2008 | 12:18 AM
SportyPig's Avatar
SportyPig
The electrical system can be a bitch.&nbsp\\; I'm getting educated on that in a hurry.&nbsp\\; In the mean time, I'm riding a SWEET Road King, but I miss my Sporty....it's a lot more fun.
IGottaRide
Sep 25, 2017 07:00 AM
Har-D
Sep 12, 2017 02:55 PM
gizzygimford
Electrical/Lighting/Alarm
Jan 18, 2017 09:52 PM
Cody Clegg
Oct 6, 2014 11:09 AM
Alan800
Apr 6, 2011 09:34 PM
