Will this setup work.
Old Oct 27, 2008 | 10:19 AM
jmbear328's Avatar
jmbear328
Default Will this setup work.
My wife is wanting to put a set of mini apes on her 07 1200C, but neither of us like the look of apes with the stock gauge/riser setup. So, I was thinking about getting a stock speedo housing and stock risers and clamps from a 1200 Low and then adding a set of factory bars from a Street Bob. I know I will have to change out the throttle cables and brake lines and clutch cable as well, and prob will even have to lengthen the wiring, which is no problem, But my question is this: Since the speedo's on both Sportsters are the same they should interchange without a problem, but will the idiot lights on the 1200C wiring harness just snap into the housing on the 1200 Low housing? Also,... was courious if anyone on here has done this swap?
Old Oct 27, 2008 | 11:12 PM
6o66er's Avatar
6o66er
Yes that will work. You can pop the idiot lights out easily. Just watch your clearances on everything and adjust accordingly...you should be good.
Old Oct 28, 2008 | 05:02 AM
jmbear328's Avatar
jmbear328
thanks for the info....
Old Oct 28, 2008 | 09:18 AM
kahaone's Avatar
kahaone
Good choice. In my opinion, apes with the stock Custom risers look terrible.
camden
Jul 26, 2014 10:37 PM
20Sporty06
Jul 16, 2012 10:40 PM
Fatbobjeff
May 31, 2010 03:33 PM
SgtMic
Apr 7, 2010 10:54 PM
lilsahara450r
Jul 8, 2008 12:33 PM
