starting problem
Old Mar 29, 2009 | 06:01 PM
ocalabones's Avatar
ocalabones
Stage III
Default starting problem
went for a nice ride no problems got home went to start to go for another ride wont start........have any ideas why? thanks for replys
Old Mar 29, 2009 | 06:13 PM
cHarley's Avatar
cHarley
Uh, ya think you can supply some useful info?
Year and model of bike.
What does won't start mean? Does it make a clicking sound? Does the motor turn over but not fire? Does the headlight come on when you turn on the ignition switch?
Or, did you just forget to put the Run/Stop switch in the Run position?
Old Mar 29, 2009 | 09:00 PM
Barrett from Mississippi's Avatar
Cool
I can get another point on my number of post here!
My guess is a Dead Battery.
When you got done with your first ride you used the Kill Switch to shut the bike off and left the key in the ON position and the bike sat there for a few hours with the headlight on and drained the battery.
Also I lived in Ocala for 4 years 1994 - 1997 nice town I enjoyed living there.
Old Mar 29, 2009 | 10:09 PM
JW1200's Avatar
JW1200
He11........I've done that!!
Old Mar 29, 2009 | 10:14 PM
anubisss's Avatar
anubisss
Could also be loose battery connections but hard to say with such little info...
Old Mar 30, 2009 | 03:20 AM
ocalabones's Avatar
ocalabones
Stage III
i have a 2001 1200 sport and i didnt leave the switch on to drain the battery it does turn over just wont start the spark plugs are getting spark just wont start after the ride any helpful tips would be appreciated
Old Mar 30, 2009 | 03:41 AM
JayStronghawk's Avatar
JayStronghawk
Have good spark that leaves fuel... Fuel+ Spark = Combustion..
Old Mar 30, 2009 | 06:50 AM
PigInaBlanket's Avatar
PigInaBlanket
Check the battery connections. When my negative cable would get loose before it would crank but never start.
Old Mar 30, 2009 | 09:48 AM
kahaone's Avatar
kahaone
Are you trying to say that your bike will crank, when the neagative cable isn't attached???? Or that you get enough power to crank the engine over, but there isn't enough power to generate a small spark??
Fine to check battery cables, but if one of them isn't attached....it won't crank. And, if it is connected enough to actually crank the motor, then there certainly is enough power for a spark.
And since the OP said he is getting spark....well.........
Old Mar 30, 2009 | 10:51 AM
PigInaBlanket
Like I said the negative cable was loose. It would crank but not start. I could tell when the cable would get loose because it would start cranking slower and sometimes start but not always. I'd check the cable and it was loose. I even tried jump starting the bike the first time it happened and it wouldn't start. I then found the cable loose and tightened it and bam it started right up.
The first time it got loose it melted some of the negative post so the cable wouldn't fit flush. I tightened it up but it would come loose gain. I finally filed down the battery post and loctited the cable and it never happened again.
Takes a couple seconds to check and make sure the cables are tight. I would advise the OP to do that.
