Stripped shock bolt
Old 06-05-2009, 09:11 PM
DallasSportster's Avatar
DallasSportster
DallasSportster is offline
Default Stripped shock bolt
I was cleaning my bike today and noticed that the left side lower shock mounting bolt was a little loose. I went to tighten it and the nut just spins on the bolt. Anyone had issues with these bolts stripping out? I have an 08 1200C with 4800 miles. Is this something that I should take care of now or have the dealer take care of it at the 5k service?
Old 06-05-2009, 09:13 PM
killer scott's Avatar
killer scott
killer scott is offline
I'd take care of it now. I havn't heard of that, and if one of your shocks comes loose "death or serious injury" could result. Just making fun of the HD manual there, but it really could throw you off and be dangerous.
Old 06-05-2009, 09:17 PM
RATROD HOG's Avatar
RATROD HOG
RATROD HOG is offline
wont tighten anymore as for it was swimming in the hole too long (bike moving up & down)
they are fine thread
let dealer look at it
Old 06-05-2009, 09:23 PM
xFreebirdx's Avatar
xFreebirdx
xFreebirdx is offline
Take it off, go to hardware store. buy new bolt and nut, put on the bike with blue lock tight, tighten to about 18 - 22 ft lbs, ride.
Old 06-06-2009, 05:20 AM
BradNailer's Avatar
BradNailer
BradNailer is offline
Take it off, go to hardware store. buy new Grade-8 bolt and nut, put on the bike with blue lock tight, tighten to about 18 - 22 ft lbs, ride.
Old 06-06-2009, 06:21 AM
hollywood1959's Avatar
hollywood1959
hollywood1959 is offline
Listen to the boy's, that could kill you! Bring it back to the stealer and have them fix it now. Don't wait. There are too many bad drivers out there that could put your life in danger if you need to panic stop. I don't want to hear about another road splat. Make sure your hardware is in good shape. Kick the tire's, check the oil, make sure she's as good as you are before you ride it. Got it? Hit this back if you have any questions...........HOLLYWOOD
Old 06-06-2009, 07:57 PM
Bentwrench's Avatar
Bentwrench
Bentwrench is offline
Default Spinning Nut or Spinning Bolt?
That shock bolt threads into the boss on the rear swing arm. The nut is a lock nut.
Is the bolt spinning when you try to tighten the BOLT or is the NUT spinning when you try to tighten the lock nut onto the bolt? If the the threads are stripped out of the mounting boss, then you will have to have those threads repaired. If it is just the threads on the bolt that are gone, then a new bolt and nut will take care of it.
Time to have an experienced mechanic look at it for you. Don't guess.
I don't know about later models, but the '92 and '96 both use grade 5 bolts, with 3 marks on the head of the bolt.
Old 06-06-2009, 08:01 PM
DallasSportster
I put a wrench on the nut and try and tighten the bolt with a ratchet. The bolt turns while the nut stays stationary. It wont get any tighter. I can back the nut off so I think the bolt threads are stripped. I am taking it in this week.
Old 06-06-2009, 11:05 PM
Bentwrench's Avatar
Bentwrench
Default Stripped Threads
If you're lucky, it will just be stripped threads on the bolt.
Old 06-06-2009, 11:13 PM
lolife's Avatar
lolife
lolife is offline
Just tie it up with some leather........ . . . .. .It will hold.................. . . . .. . .
Quick Reply: Stripped shock bolt
