08 sportster sputtering
Hello everyone! This is my first post, but I've been a long time watcher. Anyways, my 2008 XL1200c has an intermittent sputtering problem. After I got the bike, I put on a set of cheap drag pipes. Currently I have not put a fuel pak of any kind on it. The problem happens when I'm cruising at a low rpm in any gear, the bike acts like its going to shut off. If you dog the throttle when it happens, the bike comes to life and runs like a champ. It also happens when downshifting into second to complete a turn. The strange part is, when the outside temperature is warm, it usually doesn't do it. I just notice more when I'm riding to work and get into slow moving traffic. Its almost impossible to ride at 30mph in third gear. I've searched all over the internet and haven't found anything. I was beginning to wonder if it happens because I don't have a power tuner on the bike. Any help or ideas would be greatly appreciated. Thanks in advance!
-Matt
-Matt
Since you have not added a fuel management system you are most likely running lean, but that doesn't sound like the issue. It sounds to me like you are just lugging the engine. I also have a 2008 1200C and if I was in third gear at 30 I would be sputtering too. I cruise in second until 35 to 40 mph. Try running at higher RPMs. That is how the sporty is meant to run
i'll second what Dallas posted, both about potentially running lean and riding at too low an RPM. i have an 07 nightster and in 3rd gear at 30mph, the bike isnt happy. dont shift up until higher RPMs. if that works, you can most likely get away with not installing a fuel pack / power commander / etc.
