Small leak from chain inspection window
Old 07-30-2022, 07:38 AM
John Harper's Avatar
John Harper
John Harper is online now
Received 1,735 Likes on 1,190 Posts
Yes, on using only one quart for your primary and filling through the inspection cover hole.
No, on using a torque wrench on small screws, nuts, and bolts. Snug it up by hand, and err on the soft side. Or, you'll be sorry.
John
Rob Roy's Revenge (07-30-2022)
Old 07-30-2022, 10:19 AM
Rob Roy's Revenge's Avatar
Rob Roy's Revenge
Rob Roy's Revenge is offline
I agree with you there John, I've never used a torque wrench on my primary chain inspection cover screws, unfortunately the poor guy who owns the Sportster in the images below did use a torque wrench on his screws and he stripped the threads. Judging by the state of those threads he must have set his wrench to ft/lbs instead of inch/lbs.
He could tap them out to 5/16-18 and increase the size of the hole and countersink in the cover, but the sensible and most expensive option would be to buy another primary drive cover and to tighten the screws by hand, if the cover weeps after his next ride he can give the screws an extra pinch by hand.
Old 07-30-2022, 06:17 PM
LordSargon's Avatar
LordSargon
LordSargon is offline
I was just fighting the same issue, had about 5 new rubber gaskets that wouldn't hold for more than 1000 miles.
Finally got the updated thinner, metal one, coated in rubbery stuff. It seems to be holding better. However, it will also need the updated cover piece which is slightly thicker. I think it's 2010 or 2012+ have the updated part number.
I don't remember ever seeing a cardboard gasket, only metal or rubber.
Old 07-31-2022, 04:50 AM
Midpegs's Avatar
Midpegs
Midpegs is offline
Received 1,117 Likes on 630 Posts
I've bin sayin' it for years , a torque wrench is a weapon of destruction in the wrong hands .
Rob Roy's Revenge (07-31-2022)
dproto09
01-19-2017 10:07 AM
Gray_Drifter
05-15-2011 09:37 AM
tiger_rider
06-13-2009 05:05 PM
faber
10-05-2008 08:53 PM
cewood
12-28-2007 09:40 PM
Quick Reply: Small leak from chain inspection window
