wiring prob ?
Ok ,,Got a 08 nightster with 400 mi on it, from a kid that hacked it up !
I just put T Bars on it , long story short .
I just got it somwhat back together, turned the key & crossed my fingers, LIGHTS !!! wow But !! The high beam was on, hit the switch to put on low beam & POP fuse! DAM !
So bike has (high beam, running lights) thats it, no brake or turn sigz or low beam that blows the fuse ?
Any Ideas ? this sucks ..........
If it's been hacked up as you say,,,,,,,
You'll find a full set of electrical schematic drawings in the back of the Service Manual.
Buy the manual, you won't find any short answers here if someone else has done a hack job on the wiring.
Yhea I think its a short somewhere ? the left side seems to be the prob, no horn, head light, the guy put big *** apes on it and didnt do a good wire job ! geuss thats y I got it So cheap ! lol
One thing ? (does the bike have to be running for brake lights or signals ?)
Its been almost a year since I rode it & cant remember !
Thanks Guyz !!
Thank god I have my back up bike !!!!
Thanks Guyz !!
Thanks Guyz !!
Thanks Guyz !!
I would like to get a harness , But where ?? Harley makes it tuff to get stuff like that. Anyone have a good sorce ? my dealer seems like they dont want to be bothered with anything. they all seem like they r suffering from depression !
Just work on one circut at a time, the headlight circut is pretty simple and may be the root of all your problems.
Power comes from the ignition thru the fuse you blew then via the BLUE wire to the high beam switch, you obviously have a good line on the high beam WHITE wire so don't worry about that, it's the YELLOW wire that feeds the low beam and your problem has to be somewhere in that YELLOW wire between the switch and the headlight. (probably pinched at the left grip)
Once you get that working try the rest, if the rest isn't working after you get the headlight fixed repost and we will track down that circut.
Thanks Lap !!!
Will do ! I do sum more checkin this weekend, I have been using a test light & think I found the the bad guys ! like u said looks like "orange" & "yellow" from switch ! Thanks again for your help, will let ya no what happens !!
John......
John......
The signals feed thru the TSM so DO NOT use a test light on anything in that circut, in fact you should always use a volt meter/multi tester on everything these days as they have high resistance and will not allow a power surge thru the computer components in the TSM, a test light can fry electronics.
Here is the wiring diagram, you can right click on the attachment and click "open link" then you can zoom in to see it better.
