Turn signals don't work and the bike won't start
Old Oct 29, 2010 | 05:10 PM
Dynamic's Avatar
Dynamic
Why would you put dielectric grease on electrical contacts.?? A dielectric is an INSULATOR. You want CONDUCTIVE grease, thermally and electrically conductive. Check an electronic store.
Old Oct 29, 2010 | 05:21 PM
HOTLAP's Avatar
HOTLAP
This is a common misunderstanding. Like you said, it is not conductive, and therefore does not enhance the conductivity of a connection. What it does do, however, is help keep the connectors in good shape, that is, free of corrosion, debris, etc.
Clean connectors obviously work better, so by keeping the connectors clean, dielectric grease does play a part in enhancing conductivity, albeit indirectly.
Old Oct 29, 2010 | 06:59 PM
peppi's Avatar
peppi
Hotlap is correct has you covered there. You do not want a conductive grease on anything electrical (read short circuit). The dielectric grease is an insulator but it doesn't interfere with the connection, just the air and moisture that can cause the corrosion are kept at bay.
Old Oct 31, 2010 | 10:48 AM
wilburz's Avatar
wilburz
pull your cover down and listen to the start relay. i bet that is what is clicking. go get 2 relays and put and end to your missery.
Old Nov 1, 2010 | 03:49 PM
willcla's Avatar
willcla
Originally Posted by RussianMonk
I had something similar to this on my old bike. It was the relay on mine.
DO you mean one of the two relays in the fuse box or something else?
Old Nov 1, 2010 | 04:36 PM
RussianMonk's Avatar
RussianMonk
It was one of the two relays under the seat
Old Nov 1, 2010 | 06:27 PM
willcla's Avatar
willcla
Thank you all for your help.
Once I started looking at the fuses and and comparing them to the diagram I noticed that in the diagram all of the fuses were 15A fuses except for one 2A fuse. The fuse box on my bike a wonderful assortment of 30A, 25A, 20A, 15A and 10A fuses. Whoever had the bike before me must have been huffing paint because they replaced all the correct fuses with incorrect ones.
I tested the relays and they both worked
So I replaced the wrong fuses with correct fuses and the bike started right up and sounded great.
MNtadpole
Oct 8, 2016 06:43 AM
2006ultra
Aug 13, 2013 04:21 PM
Superfly3176
Apr 7, 2012 08:14 PM
JoeGrapes
Aug 14, 2009 06:12 PM
07Nightster
May 31, 2007 12:09 PM
