Yes I did about a month ago. Got a 7" headlight off ebay for $51. Has everything except the h4 bulb. I put it on a 08 Nightster, basically remove the nightster headlight and mount, drill a hole little larger than 3/8" hole in the middle of upper tree and then bolt the mount on upper tree( under side of tree is concave). mount headlight. as far as wiring went, I wanted to pull wires out of headlight plug, by pushing in a clip and pull wires out, but was unable to pull them out, so I cut the wires and match and solder them to the wire from new headlights. Using a Silver star bulb, really lights up the road.
OOOOH !! My first flame. I think it will look cool. You think it will look crap. Fair enough. I might not like your bike but then its your bike not mine. So I'll just post a picture when its done and we will see.
