1200C riser swap out help
Old Jul 19, 2011 | 12:08 AM
crazy_walt's Avatar
crazy_walt
Default 1200C riser swap out help
Hey guys i need all your infinate wisdom again. I am getting ready to swap out my C riser and speedo set up. I have a 2002C. What bike year speedo setup will fit on my bike. Also is the wiring harness diff than the other bikes. Meaning does my bike have a longer harness b/c its a C. If it is what do i do about the extra length.
Old Jul 19, 2011 | 10:06 PM
crazy_walt's Avatar
crazy_walt
Bump. Please need the help
Old Jul 19, 2011 | 10:35 PM
gilmour68's Avatar
gilmour68
Depends on what type of riser / speedo location you're looking for...There aren't a lot of readily available options for the Custom models. This is what I've done.
Attached Thumbnails 1200C riser swap out help-photo0280.jpg   1200C riser swap out help-trees-047.jpg
Old Jul 19, 2011 | 11:13 PM
crazy_walt's Avatar
crazy_walt
Yeah like that where its up top. I want like say a low type of speedo setup if that makes sense.
Old Jul 20, 2011 | 02:20 AM
Maidenas's Avatar
Maidenas
Try search on "speedo relocation", you will find some interesting ideas...
Old Jul 20, 2011 | 05:56 PM
Flatlander's Avatar
Flatlander
Just riser and speedo or are you changing bars also?
Old Jul 20, 2011 | 06:37 PM
HarleyScuba's Avatar
HarleyScuba
Quick and dirty, a 2002 Hugger had a black speedo housing, risers and handlebar clamp. It'd be easy to get the part #'s. '02 Sportsters use riser bushings in the triple clamp. '04 & up don't.
Old Jul 21, 2011 | 08:16 PM
crazy_walt's Avatar
crazy_walt
I want to do a bar swap later on. But right now just riser and speedo location change. Is there any way to locate my speedo onto the forks like the 04's can do?
jreichart
Dec 24, 2012 08:42 PM
bassnsporty
Sep 2, 2011 12:21 PM
Scott FXSTI
Electrical/Lighting/Alarm
Jun 9, 2011 11:21 PM
DFsporty
Apr 19, 2011 09:22 PM
stumpworks
VRSC Models
Mar 24, 2010 07:38 PM
