cv carb kit
Old Sep 8, 2011 | 06:10 PM
randybecker's Avatar
randybecker
Default cv carb kit
i have a cv carb on my 1987 sportster xlh883 with 1200 kit and its leaken from the accelerator pump,need rebuild kit ,the numbers on it are 27038-90A,can not find a kit,brought it to the shop to get rebuilt and they said it didnt need rebuild thet adjusted the float needel and put it on and leaks worse then before,took it apart before i brought it to shop and there was no gasket between bowl and carb,no gasket around accelerator pump and the pump cover,the shop told me there dont need any,help would be great,thanks.
Old Sep 8, 2011 | 07:23 PM
m1crazy's Avatar
m1crazy
Try the link below it should help you out.
http://www.jpcycles.com/product/4000050
HTH
Barry In MO.
Old Sep 8, 2011 | 07:26 PM
jag1886's Avatar
jag1886
There is no gasket between the bowl and the body but there is an O-ring and the accelerator pump diaphragm has the seal around the edge of it. You may still need a kit as those parts do wear out from old age.
m1crazy
Carburetor Related
Aug 31, 2011 05:30 PM
kelton3
Oct 7, 2009 08:40 PM
Mr1986FLST
Shovelhead
Apr 14, 2009 08:49 PM
eidenmar
Jul 26, 2008 08:06 AM
Hey Zeus
Ironhead
Dec 24, 2006 02:45 AM
