swapping a rear hub into a front rim
Hi guys. New here and proud to be a part of the forum. Got a question. Currently I'm accumilating parts I need for my first bike build. Bought a 16x3 40spoke rim from ebay. Thought I was buying a rear wheel but I got a front. No problem I thought. Finally scored a rear hub off of a 1985 FXST. Could anyone tell me if its possible to just swap out hub assemblies? The rear is abt 1/4" wider because of the sprocket hub but looks like it should work.
Thanks.
Thanks.
Thanks. Well, the wheel is a front wheel off of a 1991 softail heritage. Its a 40 spoke 16"x3" which has a MT90 tire w/ lots of tread left. I'll be using this rim as a rear (if possible). Recently scored a rear hub assembly from a 1985 FXR (also a 40 spoke) at a swap. Both hub assemblies have 3/4" bearings. The fxr rear hub looks to be wider because of sprocket mount. I'm unconcerned by the slight width as its going into a stock dimension 130mm rear tire rigid kraft tech XL frame. I'm curious if I can salvage the rim and just swap out the front hub in favor of the rear hub assembly? I don't know of anyone locally that has. Seems like it could. Has anyone heard of doing this? Has it been done?
Thanks Mreed. That's just what I needed to know! Its like u completely knew where I was headed. Yea I knew id have to offset my front sprocket with this build, hopefully not if it lines up and is spaced just right. Crossing my fingers as I just know the centering is gonna be a pain in the rectum lol. Mreed, that bobber is sic as hell! Is that a fatty front squeezed into a narrow glide?!?! NOW THAT IS SIC!!! How'd U get it to fit? Can't wait to finish (or start for that matter) my bobber build. U have a rear fender or are u goin gangsta and goin fenderless? With those fatties I wouldn't run any! Looks badass w/o! BTW is that a weld on tail or is that an aftermarket rigid?
Thanks once again ma bro
Thanks. That one is for my wife. She hasn't decided on a rear fender yet. She'll most likely want to run one. Something short & contoured to fit tight on the tire. It's a Led Sled 2" stretch hardtail unit on a stock 03 frame. The front wheel is a stock Sportster hub with a 16x3 rim hoop laced together with spokes I had Buchanans make. Stock narrow glide front end with the insides of the legs shaved to fit the tire. It'll be able to use stock front brakes since I used the stock hub & spacers.
I've never seen a chick ride a bobber w/o a rear fender. That would just add to the bad assness of a bad *** chick on a bad *** scoot factor. Solo seat, chick pilot, no fender...she doesn't need a fender. Hopefully U won't be the passenger on the back of her bike lmao j/k. Although I seen 2 hott lesbians riding 2up on a softail and I think I was in love! Haha. I say slap some wide white sidewalls and that bike is golden;-)
Sa-weet! Who pinstriped ur wife's bike? Here in Louisana I searched and asked high and low. NO ONE here does old school(w/ a brush) pinstripes. Actually no one is hardly. Its a dying art! And I want some pinning done on mine once I'm done w/ my project. Oh btw please convince the admin to sticky ur DIY cheapy 4" air cleaner mod! I love it I'm gonna try it! Ttyl
hawaiian Guy
10-27-2013 11:29 PM
