some nube questions
Old 01-21-2012, 10:34 PM
Adamk1200n's Avatar
Adamk1200n
Adamk1200n is offline
Default some nube questions
just sold rocket and picked up an 09 nighster.
but had a few questions.
i want to throw some white walls on it.
ive searched and narrowed it down to the avon venom.
what size should i get in the back? stock size or can i go a little bigger? or will that hurt the handling . still like to hual ***. and drag a peg on the ground.
2. i got a 2 up seat so the wife can go on a ride. i see some sissy bars with pads that say detachable.? how detachable are they, do they snap out or do you have to unbolt them.really with something quick and simple for solo then ez swap for 2 up.
3. are the stock shocks ok for 2 up. i weigh a 140 wife is 110. ive seen some different shocks out there. just didnt know if the stockers where up to the task.
soooo many mods. thanks for the info.
Old 01-21-2012, 10:45 PM
TexFF's Avatar
TexFF
TexFF is offline
1) IDK
2) QD sideplates really are QUICK disconnects. A matter of seconds but expensive.
3) Stock shocks will handle 250lbs. No problem.
Old 01-21-2012, 10:51 PM
USMCNewdog's Avatar
USMCNewdog
USMCNewdog is offline
Ok, I cant help on the tires, but the quick release detachables are just that real quick! I pop mine on and off all the time!
I am using factory shocks, we are 205 and 130, its a sporty, but there are upgrades. Sorry I am half in the bag now, and but the factory shocks are adjustable, so crank them up for the two of you then try dropping a notch at a time. We cant drop it even one notch and I got her some big nasty seat with tons of cushion for her! lol
Old 01-22-2012, 08:02 AM
chamba's Avatar
chamba
chamba is offline
I dont know how fat you can go without major changes, but you might try a search of the forum. then ask that specific question. There might be a group of us who have knowledge/interest in doing that and would comment on a fat rear tire thread.
SUPERQUICK to release the sissy bar. they are release tabs and pull.
get the tool needed to adjust the shocks. I went with Progressive shocks cause I can tighten/loosen by hand. you should be fine on stockers at the tightest position.
BTW it is noob not nube.
Wecome!
Old 01-22-2012, 08:50 AM
CRocks's Avatar
CRocks
CRocks is offline
Originally Posted by TexFF
1) IDK
Yup, he's right, the question is....can the 250lbs handle the shocks?
Old 01-22-2012, 09:06 AM
capitalist_slave's Avatar
capitalist_slave
capitalist_slave is offline
Stay with the stock size... any noticeably larger size will require major mods.
Old 01-22-2012, 01:55 PM
Adamk1200n's Avatar
Adamk1200n
thanks guys. time to start ordering some parts and get to modding.
Old 01-22-2012, 03:05 PM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,853 Likes on 2,420 Posts
If you have a 3" rim the widest Venom tyre you can fit is a 150/80, which may be stock size. To go to a wider size means going to a wider rim.
Sam2010
09-04-2017 09:22 PM
Devchonachko
12-21-2014 06:51 AM
PumpinIron
09-01-2014 02:29 PM
Mac10
01-29-2013 03:14 PM
Pitts2112
09-13-2008 06:03 AM
Quick Reply: some nube questions
