Power Commander V
Yup, ECU under the seat. Thing is there are 2 kits, one made for our 07-09 bikes with ECU under the seat, and one for 2010+ with ECU behind rear cylinder. Actually to confuse matters further I don't think Dynojet lists a compatible PC-V for 07-08, but rather then PC-III. It doesn't matter though as the 07-08 is the same as 09.
I'm sure you will get the 07-09 whereas I got the 2010+ since I bought used. You will have a MUCH easier time installing.
The PC-V includes "O2 optimizers" (resistors) that completely bypass the O2 sensors so you might as well get rid of the unsightly and heavy, expensive *** pieces of junk. Basically the PC-V adds fuel and potentially spark to what the ECU is calling for with the assumption that AFR's are a perfect 14.2:1 or whatever it is the Delphi ECU commands so it doesn't chop the fuel the PC-V is adding. I'd much prefer to just flash the factory ECU like I have always done on my V8's, but there was a $400 price difference for me and the PC-V seems to work great. If I have any issues it's coming off in favor of the Power Vision most likely, though I hate paying for the unnecessary hardware.
Nope, too hot to do any good though I'm sure there is a product out there for this app. When I sealed an EGR fitting on stainless longtubes I used high temp RTV on the brass fitting, but doubt it was necessary. On these I just tightened em up then put an open end wrench on them and tapped tighter with a light rubber mallet. Stainless is pretty "soft" and will gall some in the threads so they should stay put. I do need to go back and check for leaks with a lit cig. though. Just have to borrow one first.
Z6969
Jun 23, 2006 04:35 PM
