FYI kuryakyn load equalizers are priced at like a 1/3 of what some of the others out there are charging. Came from recommendation of HD dealer parts guy. It's what they recommend to all their customers going the LED turn signal route. Said cheap and never run into problems with them...
got me JOKER LED rear turn signals on now look great
Make sure you really need them, I put a LED tail light/turnsignal from D2 moto on my 48 and it wired straight up.
RTW.
without them blinking 100 times a second.? i think once u go LED all the way around, they go crazy.
(do you have regular bulbs for the front signal lights?)
not sure i would hold back a little..
I have only wired in my rears at the moment (as i cant be arsed to pull the tank for the fronts just yet) but i think they may all work without a equalizer as the stock rears are led anyway arnt they..
i say get your turn signals wire em in then worry about the load equalizer later if you need it J.M.O
check new thread for a piccy
just so you know i had normal bulbs on front of my last bike and LED on back and they all worked normally
Yes I have the stock front bulbs, it works totally normal.
RTW.
