Post your Dyno results here.
Old 12-08-2012, 08:14 PM
Madnss's Avatar
Madnss
Madnss is offline
Received 1,061 Likes on 573 Posts
Default Post your Dyno results here.
Is there a dyno section for sportsters? or a sticky? Can we get one or start one? Thanks Madnss
Old 12-08-2012, 08:31 PM
camcarvin82's Avatar
camcarvin82
camcarvin82 is offline
Old 12-08-2012, 08:53 PM
ev0lution7's Avatar
ev0lution7
ev0lution7 is offline
Here's mine:
2004 xl1200c cv-p carb kit. Tc88a custom map, SE a/c w/ k&n e-3040, SAMSON POWERFLOW III 2-1. I must say that I was not after a huge HP gain but smooth power I did get the "dB killer baffle" from Samson! So with the regular baffle you will prob get much more HP at the expense of more sound.
- dyno run
-bike running.
Old 12-08-2012, 10:18 PM
DK Custom's Avatar
DK Custom
DK Custom is online now
Platinum Sponsor
Received 3,960 Likes on 2,308 Posts
Here's my Stage 1 883. In a few months I'll post up a new chart after the N.R.H.S 1250 kit is installed.
I should be getting something close to this after 1250 install-
__________________
Kevin
Gear Up & Ride in! DK Custom 4th Annual Open House, June 8th. 🏍️ Click HERE For The Lowdown.
DKCustomProducts.com
Call/Text: 662-252-8828
Old 12-09-2012, 09:53 AM
Madnss's Avatar
Madnss
Madnss is offline
A thunderstorm top end with 497 ckicken cams I did almost 10 years ago. Bike pulled 82 hp without the air cleaner on.
Old 12-09-2012, 10:50 AM
cpracing519's Avatar
cpracing519
cpracing519 is offline
Heres mine. 1200cc. went from stock 72hp to 82hp. Drag race runs at 12.5-12.2 sec. @ 102-106 mph.
Mswertfa (06-21-2021)
Old 12-09-2012, 05:39 PM
grancuda's Avatar
grancuda
grancuda is offline
74.42HP w/short shots & velocity stack w/wire screen at base.
71.09HP w/short shots & velocity stack w/wire screen at base & Outerswear.
Running a Dobeck EJK & tuned it riding for about 500 miles before dynoing.
On this dyno a stock Nightster/48 run 64-66hp.
Old 12-09-2012, 09:07 PM
Madnss's Avatar
Madnss
Madnss is offline
Glad to see the dyno sticky is taking off.
Here is a build I did in 07. Same as the above one, but with ported thunderstorm heads, mikuni, thunderheader, 536 chicken cams, crane hi 4 ignition, cp pistons.
Bike topped off at 95 hp and 87 tq
Old 12-10-2012, 06:36 AM
Madnss's Avatar
Madnss
Madnss is offline
The quest for a 100 hp.....fell short that day and ended up at 98 hp 84 tq
Roughrider/desert storm (09-01-2020)
Old 12-10-2012, 07:13 AM
USAFANG67's Avatar
USAFANG67
USAFANG67 is offline
Nice bump in torque and HP!
Aside from the obvious pipes and A/C what else did you do to get nice numbers?
Quick Reply: Post your Dyno results here.
