frame interchange
Old Jan 17, 2013 | 10:24 PM
towtruckdave's Avatar
towtruckdave
Stage I
Default frame interchange
will a 2000 sportster 1200 frame fit a 1998 sportster 1200
Old Jan 18, 2013 | 07:19 AM
Sportster Spence's Avatar
Sportster Spence
Sportster frames are interchangable 86-03, so the answer to your question is yes!
Old Jan 18, 2013 | 08:30 AM
grbrown's Avatar
grbrown
Those two years have different part numbers, so there may be slight differences.
Old Apr 6, 2013 | 10:15 AM
Ronald Roach's Avatar
Ronald Roach
Stage I
I have a 2012 , 1200 motor from a bent frame..what frame must I seek out ? will a 883 frame do ?
Old Apr 9, 2013 | 10:20 AM
WVHogRider's Avatar
WVHogRider
An 883 or 1200 frame from 2007-2013 should work.
Old Sep 9, 2024 | 09:02 AM
Robby94's Avatar
Robby94
Cant L84 and 1985 models interchange with 86-03 as well? I think ive read A 01 should fit in a L84 or 85 frane if you relocate the jiffy stand because the frame has the indents in it like the newer years. Is that right? I know L84-91 are interchangeable if you do that because ive been searching what i could install in my frame if and when this engine blows up. But would much rather have the 5 speed sporty evo engine in my frame.
Old Sep 9, 2024 | 10:18 AM
John Harper's Avatar
John Harper
I thought 91-03 are the same. 86-90 may need some work to fit the 5 speed motor.
John
Vin_b
Jul 6, 2017 05:16 PM
AMP1977
Jun 1, 2012 08:43 AM
upjeeper
May 29, 2010 11:52 AM
98Sporty
Feb 16, 2007 01:39 PM
pbfloyd
Jun 26, 2006 02:13 PM
